Hi, this is a friends boat. I don't know what the boat itself is, but it's a small sport type boat.
The engine is around a 1976. It is a 3 cylinder 70 horse (according to my friend, I haven't checked any serial numbers yet).
My friend asked me if I would look at it. Before I even looked at it he had a local boat dealer try to fix it. They failed. I forgot what they charged him, but they put 3 new coils on it, "rebuilt" the carbs and I will have to ask him exactly what all else that they did. After they failed to get it to run right they told him to come get it out of their shop because they didn't want to deal with it anymore...
After that he had another supposed boat mechanic look at it. This guy told him that it needed new reeds. They bought a used set of reeds and installed in it. It is still running the same as it did before anyone worked on it.
The motor starts fine, but all it will do is surge. Like maybe it is just running on one cylinder. I immediately noticed that there was a lot of gas spitting out of the carbs with it running, so I took the carbs off of it and took them apart. The carbs were very clean, BUT all of the floats were set at different heights. And not one of the floats were even close to being set right. I have the manual for the motor and set the floats right (1/16" above the carb body when turned upside down, with the gasket installed). When I took them apart they were all set so that the float hung way down inside the carb body before the needle closed (letting way too much gas in). Another thing that I found pretty ridiculous is that one of the carbs only had one nut holding it on. And these guys are mechanics???
I did a compression test before I even took the carbs off, and they are within spec (117, 125 + 127).
I checked the fuel lines and they are good.
I checked the fuel filter and it was clean.
The engine is definitely getting enough gas.
The plugs are right and gapped to .030".
I checked all electrical connectors on the engine and didn't find any that were corroded or anything.
I checked the spark when I did the compression test, but I didn't use an actual spark tester, I just used the old fashioned touch the plug to ground and check the color of the spark method and it was bright blue like it should be.
I probably left some stuff out but I need some help with this.
What should I do next? When the engine is running you can move the "timing arm" and it doesn't make it run any better. I am a certified automotive mechanic, so I don't know a ton about outboards, but I am a very good auto mechanic. I just need some help from you outboard pros to figure this out.
I would have checked the points if it had them but this has the CDI setup.
My friend doesn't think that I can get it running right since he already had the other people work on it and not get it fixed. He's really getting on my nerves with his comments about how I can't fix this motor. So please help me figure it out.
He told me that he watched the guy that put the used reeds in it adjust the timing and says that it started running better. But my friend knows absolutely nothing about anything mechanical. He doesn't even know how to change the oil in his car. Or check it for that matter.
One more thing, when we had this thing running the first time that I heard it run, for about 1-2 seconds it actually ran great. It was like someone flipped a switch and it ran like brand new for a second or two. I was pretty confident that after I got the carbs adjusted right that it would either be fixed, or at least run noticeably better but I was wrong.
I will post a video of it tomorrow so you can see/hear it run.
Thank you for any help/advice that you can give me.
