turtle1173
- Joined
- Nov 29, 2001
- 437
Hi all,
I've got a mid to late '80's 70HP Johnson. Serial plate is gone so I don't have a number. It was a VRO motor but has been disabled. Motor had been sitting for several years. When it ran, it had just had a new ignition system installed (stator, power pack, but not sure on the coils).
I cleaned the carbs and replaced all fuel lines. And also rebuilt the fuel pump.
The motor started right up and seems to idle good. I was getting ready to take it out for a test run. What held me back was that a couple times, the rpms would really increase. Then it would go back down. It dawned on me that with the idle lever all the way up, it really wasn't idling all that fast. A couple of checks and I found that the top plug spark was very weak. The other two were "knock ya down" blue. Ouch!
I took the top coil and swapped it with the middle coil. The weak spark moved to the middle.
My question is... Can I reasonably conclude that the coil is the problem, since swapping it out changed the problem cylinder? I don't have any electrical testing equipment but I also don't want to throw money at it hoping it's the answer.
Thanks!
Turtle1173
Thanks!
Turtle1173
