1984 Ev. 70HP
I swear that I've been looking at both the parts list as well as the service manual but I can't seem to find any description on adjusting these two cables.
I'm guessing which is which but I'd rather have you say, for sure, as well as what the "tweaking" of each would do?
I was looking at that lower one (#2) and it looks to me that the P.O. had made an adjustment because the threads are somewhat cleaner (Between the 2 and to the left of the engine colored housing).
Since I just got this motor about 4 outings ago and only recently experienced a possible "clutch dog" clunk (which happened once at very slow speed [more of a clatter in a shallow area] and once a little later at mid speed [more of a clunk]), I'm wondering if screwing this in or out a little more may contribute/alleviate the problem. Seems to shift fine, though, the way it is. Unfortunately it was too late so I didn't mess around to replicate the issue.
Also, I labeled what I believe is the idle speed screw, correct? I'm trying to figure out why the manual states to disconnect other stuff rather than just screw it in/out a little at a time (like a one-step process after warming it up and putting into gear) and wait to see how it responds?
