I recently bought a couple of mercury 9.8's. I put the two together and made one good running one. The fellow gave me an impeller that he thought went to the motor. Im pretty sure the lower section is off a 71 model. I pulled the lower unit and removed the worn out impeller. The new one slides down the shaft to very near the bottom where the shaft seems to get just a tad larger in diameter. There it wants to stop. I checked the old one and it will slide onto the larger area with a little effort. The two impellers look to be the same as far as the blade diameter but when measuring the bushing in the center, there is a few .000's difference in the two, being the old one is the larger. I guess what I need to know is do I try to knock the new one down the shaft or do I have the wrong impeller? Is there another impeller that is suppose to fit this unit? If so what do I ask the partman for? Thanks, Chris
