Hello,
I've got a 9.9hp Johnson, either a '74 or '76 I can't remember and have two problems with it.
First problem. When I go to start it I have to remove a plug and put some fuel in a cylinder otherwise it will not start. Carb is clean, bulb is pumped until firm. As long as I leave the fuel hooked up it will re-start all day long. If I let it sit for a day or two or disconnect the fuel line I have to repeat the manual priming. How can I fix this?
Second problem. When in gear, usually the faster I go the more it happens, it will pop out of gear (but shifter stays in gear) and the motor will rev up. I idle the throttle back, shift into neutral then back into gear and carry on. What's the problem here? Also, I'm not sure if this relates but the throttle twist grip is way off. First 1/4 to 1/2 of the turn is nearly useless, I can't seem to adjust it properly.
Any and all help is appreciated so thank you in advance.
