Hello,
I am by no means an expert when it comes to working on motors but I have done routine maintenance on mine for the last few years without issue. Long story short... I have my boat stored at a house where there is no running water in order to run it and do some carb cleaning and to make sure it will run this season when I put it in the water. The motor is a 45HP from the 70's, I believe 1975. With it not being at a location with water, I brought the motor home with me and have it stored in my garage on a stand that I built since last fall. The motor has electric key start, but that's built onto the boat and would have been a huge pain to disconnect all that as well to bring it home with me. I'm wondering if there is any way to run the motor manually? I've read some posts online and some say it's okay while others say you shouldn't, so any insight would be very helpful. I'd really prefer to run it here at my house and do some spring cleaning on it while also making sure it made it through the winter just fine rather than trying to put it in the water and find out it won't turn over and I have to take it out and bring it all the way back home.
1.) Can I use a pull cord on this and manually start it?
2.) Anything I would need to look out for?
Any thoughts would be greatly appreciated.
Thanks,
Mike
Thanks,
Mike
