Got another question on my 71 25hp Evinrude (25102S).
As shown in the service manual, the prop shaft has a hole in the shaft that carries a spring-n-ball detent setup for the clutch dog. It snaps it into forward, reverse, and neutral.
The trouble is this...
The prop shaft was bent, so I scored a complete 18hp lower unit with wornout gears/dog on ebay for parts. I don't know the exact year of the 18hp lower unit donor, but it's the same as mine.
The donor's prop shaft doesn't have the hole for the detent setup, but I installed it anyway. Now, the dog depends on the detent on the shift lever assembly (up on the powerhead) to hold it in gear. It doesn't.
With the old prop shaft the dog/gears did not jump in either forward or reverse. But with the donor prop shaft it jumps in forward. The clutch dog and gears have very minor wear and were fine before so they should be fine with the new shaft too...or so I would think.
Anyone else ever have this problem? I think I'm going to have to crossdrill the 18hp shaft for the detent spring setup to hold it into gear. Anyone see a problem with doing this?
My friend also has a '73 25hp Johnson on their pontoon. This motor doesn't have the detent setup on the prop shaft either... We just replaced the dog and I milled the gears to remedy it's gear jumping problem. It's working fine, but we would consider drilling this one for the detent too if it would be beneficial to preventing wear.
Sorry for the long-winded post...
