apparently no one in the last 40 years has bothered to replace the lower water pump seals. after I got that apart I discovered a BADLY pitted and grooved shaft. the diameter is about 1/8" less in the seal area that the rest of shaft:facepalm:
every where I check the shaft is no longer available. does anyone offer a repair sleeve of some sort? should I have a machine shop fix it?
FWIW it is a 20" motor and the shaft has the spring loaded pilot pin on top
