I am trying to get a new to me 1971 60hp Johnson running. It is turning over fine and the lower end appears to working fine as well. My problem is I am getting no spark.
Another poster here graciously sent me a copy of the ignition chapter of the manual until I get mine so I decided to start testing components.
I started with the amplifier, but I've got a question. It says to remove both purple leads at the terminal board and connect a low reading ammeter between the purple connectors. Am I supposed to connect the ammeter between the two purple wires themselves or between the 2 wires and the terminal board?
I also have a purple wire (looks purple anyway) that is not connected to anything. It runs in a harness that runs down to what appears to be a sensor in the lower block. I have attached a pic of the wire as well as where it goes below. The second wire in the harnes, that comes from the same sensor, is grounded right behind where the loose wire is.
Also, any thoughts on common components that tend to go bad easily and how to test them would be appreciated as well. I know sometimes people learn little tricks that the manual doesn't have in it.
FWIW, the amplifier has been replaced and it looks like the coil as well.
