ultra353
- Joined
- Jun 21, 2009
- 388
I'm Not used to this type of system, opposite of the omc points setting, I have this motor and replaced all of the frayed, cracked wiring that was shorting out the motor. It had weak spark on both cylinders so I hope the stator is in working order, just bad wiring and dirty points.The points were pretty bad shape as well so I removed them to thoroughly clean them. I don't have a manual for this motor so would someone walk me through the process of setting /adjusting the points. I'm used to the omc system. Thanks
