Model 60173E with Selectric control. Intial problem discovered when boat would only move very slow and water had gotten into the Gearcase. I removed the gears and found that the notches had been worn down; also the notches on the Clutch Dog were worn. I assume the problem is that the Clutch Dog is not being forced far enough to make correct contact with the gear notches. Question is: what is the cause. Will water in the gearcase cause this? or could the Oil Pump the problem? Is there any way of checking the Oil Pump (list price of $585.00)? I took the gears and Clutch Dog to a welding shop to build the notches back up. Both gears list for $652.00.
