71 evinrude lark runs great,runs better with hood off
mirage5058
Anyone ever had this issue?My 71 50hp evinrude lark runs good,but a little rough with hood on,when you take hood off it runs almost perfect,any ideas why?
jonesg
Re: 71 evinrude lark runs great,runs better with hood off
an exhaust leak can choke the carb intake, they like fresh air.
also see if you can feel any voltage around the cover near the sparkplugs, could be ignition spark jumping to a cover lock .
jtexas
those two holes on the back of the motor below the cowl are "exhaust relief ports" -- the exaust housing cover just above those holes, see if the seal is still intact.
jay_merrill
Your motor is a hydro-electric shift model. There are a pair of wires that run from the inside of the lower cowl, on the port side, down into the exhaust housing (midsection). You will see a pair of connectors with rubber boots on them, right next to the point where the wire runs down into the housing.
Exhaust leaks at this point are very common. The wiring section that runs through the housing is encased in rubber and has a bulb just below the adapter plate, which is an aluminum block that is installed between the top of the exhaust housing and the bottom of the powerhead.
To determine if you have an exhaust leak, remove the engine cover, run the motor and watch for "smoke" coming from access port that the wire runs down into. You may also see soot marks in that area.
If you do have a leak, it needs to be stopped, because motors usually don't run well when breathing exhaust gases. To do this, you will have to gain access to the adapter plate, by removing the exhaust housing covers. These covers look like a "ring cowl" and consist of a front and rear piece. They are held in place by four screws that run from inside of the lower cowl, down into the pieces, and by four screws that hold the front and rear sections together.
Once you gain free access to the port in the adapter, you will need to seal the wires. Lack of a seal is usually the result of the bulb in the rubber casing not being pulled up into the adapter plate, but I don't like to pull on the wires to reset it. These wiring sections are no longer available and they sometimes become brittle. For this reason, I prefer to simply seal the port by injecting temperature resistant silicon into the hole, around the wires. I apply the silicon liberally, so that a plug forms around the wires.
Take a look at your motor to see if this might be your problem. If not, let us know and will try to offer further guidance.
mirage5058
Thank You,That was the problem i recently replaced the impeller,when i pulled the wires back up through the unit i did not check tomake sure the plug was sealed correctly where the two wires come through there was quite a bit of exhaust coming out i sealed as told now no problems,Thanks so much
