Please Help.
I can't get my engine to fire up without spraying started fluid into the carb.
I haven't ran it for two years, but it done this before. When its was warm, it started fine. However, with first start and when I went fishing and sat for several hours, it wouldn't start very easy. It took a while to start and I kept wearing down the new battery. Now I can't start it without started fluid.
I just learned a few minutes ago that I should be using a spray bottle with mixed gas in it instead of started fluid.
Anyways, I checked the compression and all four cylinders are running about 100 psi. I also have new spark plugs
Can anyone give me any other suggestions about what to do? I'm not very experienced at this stuff. I even called some of our local repair shops and they tell me to buy a new motor. But, I can't afford that. This one seems to run fine once it gets started. I'm just afraid to trust it right now. The last time I used it, I had to row back to the dock... I didn't know it would start with the started fluid. I learned that after I got it home.
Can anyone help me? Thanks.
Jerry
Jerry
