'71 Johnson 20hp Smokes and Jerks
Bass2ply
This motor is a little hard to start and sneezes a little when it first trys to turn over. After I get it to run, it jerks a lot at idle and dies. If I push the RPMs, it won't jerk as much. It will die when put into gear. Sorry, I don't know a better word for it than "jerks" because that's kind of what it does. Also, it smokes a lot, but I know it isn't the gas because my other outboard ran clean on it. I have replaced the head gasket, plugs, and it has good compression, spark, and cooling. I am green on outboards and certainly frustrated. Any suggestions?
D
DJ
Guest
Re: '71 Johnson 20hp Smokes and Jerks
Bass,<br /><br />Usually, a "sneeze" is indicative of a lean mixture. Has the carburetor been disassembled and cleaned lately?
Bass2ply
Not to my knowledge; I just recently acquired this motor. I did try to adjust the low speed mixture while running, but it did not improve the problem. I will look at rebuilding the carb.
