My 1971 johnson 40hp has suddenly started to miss terribly on one of the two cylinders. Compression check ok on both....fuel check ok. I suspect a bad point/condenser under flywheel. My problem is that I can not get that darn flywheel off. I got the main center bolt off and I am using an harmonic balancer puller with the proper three pulling bolts. No matter how tight I get the puller bolt or how much I tap on the puller bolt I can't get the flywheel to pop off. My question is can I apply heat to the center of the flywheel to get the aluminum flywheel to expand or will the heat cause to much damage inside? Any help in this matter will be greatly appreciated!!!
