Ok, but does it really "pump"? The only source of power I could think of might be pressure in the fuel line. I'm struggling with this, please explain. I want to figure it out without taking it apart, I wouldn't be able to get it back together.<br /><br />ThanksOriginally posted by Walker:<br /> Pump. It has a screen in it that I guess you would call a filter.
There should be 3 lines to it. One to the carbs, one from the fuel tank, and the third line is what powers the pumop. It goes to a fitting on/in the crankcase. The pressure ans vacumn pulses from the crankcase make the pump work.The only source of power I could think of might be pressure in the fuel line
I'm sorry, I wasn't clear. I don't believe there's a problem with it, I was just curious about how it worked. I think I understand know, thanks for the replies.Originally posted by Joe Reeves:<br />Are you having a problem, and if so, what is it?
