Hello Im trying to get an old boat started ..that sat for 8 years..assuming it is a johnson 50hp model 50esl71s...there is a throtle that when in forward position is the only way to turn over...someone installed three switches on the dash which is supposed to be forward neutral and reverse...cant get it start though as it seems like its working to hard spinnin the prop? is the prop supposed to spin when starting? is there any way to manually put the motor in neutral?..maybe I need to rewire this thing?...geez more work!
