BigDukeSix
- Joined
- Dec 13, 2011
- 11
I have a 1971 Johnson 60 hp hydro electric shift. Motor has been pretty dependable over the last year. Started acting up recently. I rebuilt the carbs. Checked compression (all at 120psi), and put in new plugs. My current situation is this, it will start and run perfect on muffs. It will not start when put in the water. The spark is there but weak when the boat is in the water. I can tilt it up out of the water and wait a minute or two and it fires right up. I drop it down and off I go. If I shut it off I have to raise it up out of the water and wait a minute and it will start right up. My reverse doesn't work (wiring and switch checks out so I am thinking a bad solenoid). I am wondering if that bad solenoid is grounding against the case causing a drain from the amperage going to the ignition system during cranking. Any other ideas? Thanks
