njmedic3306
- Joined
- Apr 27, 2010
- 69
I JUST got a sailboat with a Johnson 6hp long shaft that I ran in a garbage pale for 3 minutes with enough water. There was NOTHING coming out of the pee hole when it runs at idle. So I figured WATER PUMP.
However when I pulled it apart the impeller and casing looked new. So I pulled the stainless steal panels off both sides of the lower unit and cleaned it out. Reassembled and it is still not peeing. WHAT IS GOING ON??? It has to be getting water or the impeller would had been shot.
Could it have to do with the thermostat?
