natemeins
- Joined
- Oct 20, 2013
- 73
Hey fellas. Wasn't really sure how to title this, hopefully letting me explain the details will help.
New motor to me, I love Johnnyrudes, I had an outstanding little '84 30hp before this one, so I'm kinda familiar with them.
As far as I know on the history: the engine/boat show signs of living in a slip on the lake for many years. The previous owner bought it almost 3 years ago and it has sat dry, with the occasional start. Makes good compression, good spark, turns over with authority. I rebuilt the carbs, set float seat and drop, rebuilt the water pump, flushed/filled gearbox oil, went through the electrical, and gave it a good cleaning up and general maintenance "once over". The coil packs appear to be original, as the high tension wire insulators are cracking, and the metal insert in the plug boots were pretty rusty. Cleaned them up enough to make good contact with new-looking plugs (they're NGK rim-fires, the ones with no electrode tip? My research shows they are adequate alternatives to the proper Champion plugs). Got the engine back together, and did the link & sync. I did NOT touch the timing advance stop or the cam linkage, only adjusted the roller to center on the mark on the cam. I also verified the linkage between the carbs were such that both butterflies were synced properly. Got it in the water, started it up, and adjusted the low speed needles. Idle sounds good and smooth, but throttle lever is pretty high on its travel to maintain idle. High speed is good, transition is good. But if I pull the throttle lever all the way back to its limit the engine will surely die. With the idle stop screw screwed in all the way, the vertical linkage will not touch it and maintain idle. I tried adjusting the black plastic barrel on the throttle cable to no avail. All it did was push the settings further forward to the point I had to bypass the safety start switch just so I could get the throttle high enough to start it cold. Needless to say, I ran out of throttle adjusting barrel threads and I still can't bring the throttle lever all the way back and maintain idle. While the engine was idling properly, I shut it down and had a look at the linkages. The cam is well into its contact with the roller and has in fact started moving the butterflies open. Not much, but they are not fully closed (should they be?)
Am I asking too much from this setup? This is my first time with this type remote (Selectric, single cable for throttle), my little 30 had a simplex type remote which were separate levers for throttle and gear shifting, and the throttle linkage on the engine had an idle limit screw you adjusted on the outside of the cowling where the cable attached. I always had it set so that I could pull the throttle all the way back and it would have a nice idle in gear, perfect for trolling. Shouldn't this remote do the same? Is it possible I still have a circuit clogged on the carbs? Could the idle timing be wrong? Or have I just not set the cable up properly? I did have both ends removed so I could remove the cable from the housing for cleaning and lubrication, when I reinstalled the ends and tightened the grub screws, could I have not set them properly? That seems a stretch but I'm grasping at straws at this point. As I said, the engine will idle and run very well all day, so long as I don't pull the lever back all the way.
Any ideas, suggestions, questions I can answer, or comments would be greatly appreciated. Thanks everyone.
