The motor stalls as soon as I put it in gear. If I move the choke lever all the way back the engine winds to top RPM in nuetral. I have found that I can jockey the choke and get the thing to keep running sometimes. It will go in gear and not stall if I choke to higher rpm and engage. (I had to do that to get it off the water on my first time out, otherwise I would never do this)
I am thinking carb issues since it stalls out only when it is initially put under load.
Thanks
Casey
Thanks
Casey
