Re: 71 Thunderbird tri-hull bowrider wet foam and deck
Scooty, I knew my boat was junk when I got it. I had originally got it for the motor, but also as a potential project. My project is not a restoration, but a conversion. An old 70s tri-hull probably wouldn't be my first choice for a restoration, there are other more "worthy" boats out there. I realized my old tri-hull was the perfect platform for a center console, something I have wanted for some time. My particular tri-hull has aggressive lifting strakes and a deeper V to it, so it won't be quite as pounding in the rough, and it will be very stable. When I actually tore into it, I almost abandoned the project. All that ruined structure was disheartening to look at, even though I knew it was there. All I needed to do was saw the boat into four equal pieces and haul it to the dump, but I didn't. I got through the nasty part, and now I am to the fun part.<br /><br />Don't let anyone disuade you from your project. If an old 70s tri-hull is what you want to rebuild, then go for it. If nothing else, it will be good practice for the next one you do (and there always is a next one-I am on my second). I think my next one will be one of those 50s ones with the big fins and all that. They can look pretty cool when restored, and are starting to become worth something again. Anyway, good luck, and try to get us some pic....
