Re: 71er 60 HP Johnson Impeller change
Hey Black Spark. Welcome to the forum.<br /><br />Taking for granted your engine is an electric shift, did you disconnect the wire harness to the lower unit? The knife connectors are under the "hood" probably on the starboard side of the engine. Look for a green and blue wire. Disconnect and tie a piece of string on to the harness where it goes to the midsection. Gently pull the lower wire harness from the engine area. A little lube here will help. The string is to help pull the harness back up through to the engine so it should be a strong string or a wire will do also.
