71EVINRUDE125 NO SPARK
JJS3
I JUST BOUGHT 71 COBIA WITH 125HP EVINRUDE OLD OWNER HOOKED BATTERY UP BACKWARDS REPLACED PULSE PACK SENSOR UNDER FLYWHEEL RECTIFYER DIEODE CLIPPER CIRCUT COIL WHEN HE FIRST DID THIS HE REPLACED THE INGNITION SWITCH THEN THE OTHER PARTS HE LATER FOUND OUT HE HAD SWITCH H OOKED UP WRONG SAID ITS HOOKED UP RIGHT NOW WITH KEY ON IF I TEST TERMINAL BLOCK ON BACK OF MOTOR I HAVE POWER IN LIKE LAST 4 BLOCKS BUT LIKE 1 THROUGH 5 ARE DEAD SHOULD I BE GETTING POWER THERE IF SO WHAT COULD BE WRONG IM AT MY WITTS END WITH THIS I SURE COULD USE SOME HELP THANKS
R.Johnson
Re: 71EVINRUDE125 NO SPARK
The system you have is not an easy one for a beginner. You are dealing with components that can get very expensive, and difficult to test without proper equipment. Going down the list, you have an anti-reverse spring, ignition sensor,clipper circuit, pulse pak, Ign. coil, key switch. Any one can stop this system cold. By the way, that system does'nt like low batteries either.
JJS3
thanks for response R. Johnson i did in fact go out yesterday and buy a new battery 1,000 cranking amps and still nothing. just cant figure out what else the problem could be, everything electrical has been replaced or in working condition. im just wondering now that when the past owner had it and hooked the ignition wrong and then hooked it the right way if something didnt happen there. could it of done damage when hooked wrong and they were trying to start it?
JJS3
do you know where the anti-reverse spring is on the motor?
R.Johnson
It's a friction spring that slips around the crankshaft, under the timer base.
