72 115hp ignition problem
birdnbuck
This motor set for a while so I replaced switchbox and rectifier. I had it running great. Ran it just three days ago. Went out to start it today and no fire to plugs but it fires when you are turning the ingniton off. Any ideas.
tashasdaddy
Re: 72 115hp ignition problem
i open a 1971 1350 control box once. the insulation, was gone, sound like you have the same problem, wires or the ignition switch shorting out. if the kill is grounded it will not fire.
timmathis
Also could be a bad key switch. That can cause that motor to fire when you turn it on or off only.
See the troubleshooting guide at
www. outboardparts.com
Click on mercury then troubleshooting on merc batt cd ignitions. Tim
tashasdaddy
Tim and Clams know more about mercs, than i'll ever know. but i like my omc's.
