catcatcher
- Joined
- Dec 9, 2007
- 33
This has been a great motor since my Grandad bought it new. The problem I am having with it is when it is at a idel it pumps water fine. At full throttle it doesn't. I checked the impeller and it is fine, the keeper that holds the impeller in place is still there. The head gasket was leaking water from around it and when I pulled the head off the head gasket was trashed so I thought I had found the problem. After replacing the gassket it has the same problem.
On the lower unit there is a hole beside the front bolt hole that I noticed bubbles comming out of when running it in a barrel. I have never noticed them comming from this hole before and was wondering if this could be an indication to what the problem is.
Any advice would be great as I am out of options!
