Not sure how to tell if my water pump is working correctly. I installed a new impeller, cleaned up the pump and installed it back per the service manual. I put the lower unit back on last night and ran it at idle with muffs. Water is coming out of the slits above the cavitation plate as normal. I filled up a barrel with water and ran it in that at idle and I have water coming out of the exhaust port midway up the motor also. I felt around the motor to get a sense of the temperature and just aft of the metal 'eye' that you pick the motor up with if I put my hand on that area, I can't keep my hand on it it is hot. under the flywheel on the side of cylinder wall it is warm and I can keep my hand on it. the area around the spark plugs is warm and can keep my hand on it...its just that area on top between the flywheel and the metal 'eye' or ring that you hoist the motor up with. Is it working properly or what?
