If it's got a tell tale, then yes. Some of the old mercs do and some do not.. However, a good rule of thumb is to replace the impeller on a new to you outboard
Replace the impeller. A MUST. when you pull off the cover you will know if it has a tell tale/ pee. A hose from the top of the head to the bottom of the cowl.
