some one sugested i start a new thread for this problem, so....<br />when rebuilding the ignition system to fix a miss fire in the top cylinder. i managed to take out a bolt that was part of the link that held the throttle assembly in the tiller handle from comming out completely. so after two weeks of thinking and research and a couple of bears staring at it. i fured it out. i took apart the housing where the tiller handle connects to the motor(did no good). few more drinks and a few choice words later i fugured it out.<br /><br />1. remove the phylups head screw from the upper section of tiller handle.<br />2. slowly remove tiller handle(pay attention to spring, waher and plastic cap that lie beneath handle.) <br />3. at this point the shaft with the gear on the end will drop out of the tiller arm housing.<br />4. reallign as requierd for proper range of motion.<br />5. re assemble in reaverce order of dissasembly<br />6. ****note to self to save time, WHILE REBUILDING IGNITION SYSTEM DONT TAKE OUT THE BOLT THAT PREVENTS THE GEARS TO UNMESH.<br />7. drink beer and relax.<br />this worked for me hope it helps someone else in the future. or maybe it wont.<br />please add or critisize as you all se fit.
