mike64
- Joined
- Apr 10, 2008
- 1,042
bought my boat & motor last spring from an old outboard mechanic (not an old mechanic, a guy who specializes in old outboards)-- he said he pressure tested the lower unit and replaced oil and seals. Said I should replace the oil and check for water in the oil 1/2 way through the boating season. Since I've only taken the boat out about a dozen times, haven't got around to it yet, but I'm thinking I should before this last month or two of boating season. Here's what I understand about the process from other posts, with questions:
I apparently need a torque screwdriver to unscrew the upper and lower screws. The lower comes out first, put down a pan to catch old oil, and unscrew the upper so the oil comes out. Right?
Is this where I do a 16-18 psi pressure test, withOUT oil? Does a pressure test need to be done every time the oil is changed, or just if there's water in the oil? where would I buy a pressure gauge-- auto parts store or marine supply, and about how much are they?
Adding oil-- I know for the hydroelectric drive I need the "type C" or premium blend oil. Does it come in a self-pumping type canister with attachment, like it appears to in the manual, or do I need to buy something for that?
The oil is pumped in from the bottom until it starts to come out the top opening, correct? Then replace the gaskets on the screws, reinstall top screw, then bottom screw and done...? I saw one post say they like to replace the screws too. Is this necessary or just the screw gaskets?
Do any other seals need routine replacing when changing oil, or only if the pressure test fails?
Finally, since I'll need to do this again when I winterize and I'll probably take the boat out only another 1/2 a dozen times or so, do you guys think I could get away with just doing it when I winterize, or is it a good idea to change the oil now?
Thanks, hope I didn't throw too many questions in there at once...
