mike64
- Joined
- Apr 10, 2008
- 1,042
I had posted a follow-up to an earlier thread about this I had going but it was pretty long-winded and didn't really ask a question. Which I think is why nobody replied after a certain point.
I hope it's within guidelines to ask again and try to be more clear this time.
I'm getting water in my LU. I suspected the seals in the bearing housing under the water pump, right here:
So I replaced the seals (there are two, you see the top one in the pic) and did a pressure test. It seemed to hold pressure fine.
But after taking the boat out I check the oil and total milkshake again. I do another pressure test, and the LU held pressure for about 1/2 hour.
So I replaced the driveshaft seals and the plug gaskets. I didn't mess with the prop seals. But the LU holds pressure.
So my question is, if it's holding pressure, how is the water getting in? A wobbly prop/driveshaft? Can I just buy LU oil in bulk and just replace the oil every couple times I take the boat out for this season? I don't have the time or the money to keep messing with it.
