well i thought i had all the small issues done, but i ended up buying a new lower unit case assembly due to finding a freeze crack in the old lower unit case, it came preinstalled new drive shaft seal and shift rod oring with bushing, i replace the case used a new seal kit and left the seals in that came in the new case, got lucky and found it online, i used a air regulator i have and applied 4 to 6 psi to the case thru lower drain hole and it held 6 psi fine, put it on run it about an hour in gear and took it out of the barrel and noticed after about ten minutes there was gear oil mix coming out weep hole where water drains from, so pulled it off, replaced the drive shaft seals with the ones in kit , new case only had one seal, so put new two seals in seal lip down on both seals, ran it again for about an hour still have some gear oil/water mix coming from weep hole, i have a new bushing and oring on the way, is there a way i can save the new bushing thats in the housing ? the last time i had to replace a shift rod oring i used a 5/16 tap and pulled it with a long bolt ruining the bushing , is there another way to take the bushing out ????
