72 Johnson 9.5 water pump
solomon
Someone gave me a 72 Johnson SeaHorse 9.5 Model# 9R-72M. It only has about 25 hours on it, but it's been sitting up for years. I was going to put a carb kit on it. Should I replace the pump, and if so should I buy a new pump or a pump kit or just an impeller? Does anyone know the part #'s to look for?
Goodoleboy
Re: 72 Johnson 9.5 water pump
Welcome to the forum!<br /><br />You should be ok with just the new empelar. And as you said clean and rebuild carb.<br /><br />sorry I cant help you with part num. but local dealer should have what you need. Even napa auto parts mabey. Just give them model number.<br /><br />Good Luck!
solomon
I guess I'll have to buy the parts separately. I was hoping I could find a whole kit, or am I missing it? Anyway thanks for the link.
solomon
wait, I didn't see the water pump kit part number on the drawing. Only $39? That's cheap. A lot cheaper than buying the parts separate! thanks again.
