speedoflite2
- Joined
- May 25, 2009
- 56
How difficult is it to trace an electric choke issue? MIne used to work but now it doesnt have to use manual choke havent touched anything on the motor or controls not sure where to start
When you use the manual choke what position do you leave it in? If it's in the manual "off" position it won't work from the switch. It needs to be in the "auto" position so the switch will work.
Now, regardless of what position it's in at the motor the plunger should work. If the plunger doesn't work with the switch (key on) then you have an electrical issue.
First jump the choke as I said, and see if that's working.
