redheaddiesel
- Joined
- May 7, 2009
- 35
I have a 72 Johnson seahorse 6hp long shaft on a 12? jon boat. The problem is that it lacks power/ is running poorly. I?m not sure if it is a miss or a carb issue. I have a lot of hours invested in trying to fix this with no success. I?ll try to describe the symptoms and some of the history:
o The poor running is kind of like when you are dialing in the high speed air mix of a chainsaw: when you get it too rich and it is no longer ?screaming? with clean power and begins to flubber and lack power?only this is a very inconsistent flubber.
o It does it at all RPM?s
o At high speed it sounds like: ?ehhhhhhhh rrrrrr ehhhhhhh rrrr ehhhhhh unghhhhh rrrrrrr unghhhhh rr unghhhh
o At idle it is more like ?bum bum bum g?du g?du bum bum bum?
o At each point where it bogs ( the rrr/unghhhh and g?da) the powerhead shakes to the side like a twitch or tick
o It never happened when I first got the boat a couple of years ago. Then it would happen after about 20 minutes of running. Then I?d get a few minutes of clean running before it happened. Now it is immediate. Perhaps it is temperature related?
o The electronics were supposedly replaced five or six years ago before sitting three of four years. (they look pretty new)
o When I got the boat I disassembled and cleaned the carb (with a kit, including the metal plug) and put two fuel filters on the line. It ran well for a while. Since this problem has developed, I?ve gone through the carb a bunch of times (can of cleaner and compressed air) and makes no difference. (But I haven?t used any wires/pipe cleaner tools)
o I?ve since cleaned and adjusted the points.
o One strange occurrence: I was running 87 octane w/ ethanol when I first got the boat (for a couple of years/but not a lot of boating). In June, when the boat began to act up, I emptied the fuel and switched to 93 no ethanol. As soon as the 87 ran out of the line/carb and the 93 entered, the boat ran the best I?d ever experienced?.for about 20 minutes. Then it went back to more of the same, just slightly less severe.
o If I slowly pull the choke closed while running it makes virtually no difference until it is mostly closed where it just bogs down.
There is probably more info I should be giving and haven't. Let me know if this is the case.
Any thoughts or suggestions as to what to do next or what the problem might be would be highly valued.
Thanks in advance,
Matt
Chattanooga, TN
Thanks in advance,
Matt
Chattanooga, TN
