I rebuild the engine on my 50Hp Johnson last summer/fall and put it in the water ran it for quite awhile and then tried to take it for a test drive and it would not go into gear. i had changed the oil in the lower unit earlier in the summer, and only ran it in water once. i checked it after i pulled it from the water and it had about 1/2 cup of water in the oil. this is a hydro electric
do i need to rebuild the lower unit? if so how big a job is that and can i get parts?
