Still trying to figure this out...I had this powerhead professionally rebuilt last year. It runs good at low and mid RPM's, but when i try to open the throttle wide open it will go into a muffed kinda sound and it starts blowing gas out of the carbs. I can only run at about 3/4 throttle, anymore and it starts blowing gas...I have to pull way back on the throttle and basically start over throttling up again. All obvious things have been gone through, new internal electrical harness, complete new fuel system (except for the gas cans) carbs rebuilt per my Mercury manual specs for float lever clearance etc. Prop is original to the motor (17 pitch i believe)...timing is 21 max advance...What could be going on here??
