72 Merc 65 hp questions
SHickey
Hello,
I ran my new "old" motor in my driveway to mess around with the idle and cable adjustments. The motor started right up after I manually choked it and it seems to be a pretty smooth running motor. Much to my surprise I noticed some water weeping around the 2nd and 3rd cyl spark plug indent area. At first I thought it was coming from the spark plug threaded hole area but no, the spark plugs were in tight and this weeping is coming from somewhere else. Maybe I have a leak in the head gasket?? Hopefully someone can help me with this situation. I do not know how serious this is for the motor.
Could someone recommend a reasonably priced tech I could use with this 3 cyl motor? It seems like most techs can be set up for 2,4,6,and 8 cyl motors. I would like a 2" diam if they are available.
Lastly I would assume the black button on my control is for the choke solenoid. The choke does not work from the controller and I was hoping someone might help me get that operational.
I would like to test out my new motor next weekend so I have some time to work out the kinks.
Thank you to who ever responds in advance. You fellas are all very helpful.
SH
turtles11756
Re: 72 Merc 65 hp questions
as long as the spark plugs are not wet internally run the motor till you learn more it may just be a simple gasket. there is no head gasket but a water jacket gasket
