Hi; I've been working on a friends motor, a 1972 Merc 650 4 cylinder. It ran fine until the corroded distributor wires shorted out at the distributor. Put in a new distributor and used the old cap. Did not remove the flywheel or any other components. Now the TDC mark lines up with the distributor when number 3 cylinder is at TDC instead of number one. With number one at TDC, the flywheel is 1/4 turn BEFORE the timing mark. At this point I am thinking of pulling the flywheel and repositioning it, but I shouldn't have to since it was running well before. Could I simply change the wire positions? Or is it possible the distributor cap is rotated? I didn't think there was enough play in the wires to do that. Any advice would be helpful. I do have the manual, but it doesn't cover this.
