need help with this one, I've got a 16 foot stylecraft fiberglass boat with a mercury 1150.
right now my ventilation plate is level with the bottom of the hull, I want to raise it up a bit maybe 1 inch to an 1 1/2, my shocks a dragging in the water causing alot of spray, the only problem is there is not alot of room above the transom for the clamps.
what's the best way to add material to the top of the transom for the clamps to grab onto.
I don't want to lose this fine motor, right now there's about an inch from the top of the clamp to the top of the transom.
I'm also looking for a little more speed, right now I'm at about 31mph, I've got doelfins on right now that I'm going to try taking off also for more speed. I don't have a tach and I'm running a 3 blade 17p prop
any advice? thanks J
