Super Dragpack
- Joined
- Jun 7, 2010
- 22
Hi all,
I have just purchased a circa '72 Mercury 800 80hp 4 Cyl outboard. I have a few questions but the first if the ignition system.
It has a basic system with a distibutor and coil etc and I have no spark.
The wiring is very poor so I am sorting the old wiring (got a wiring diagram from online) but its seems that the wires to the switch box are different than in the diagram. There are only 4 terminals on the switchbox but I can't work out what the box actually does on this motor.
The stator/altenator and rectifer are very seperate and not connected to the ignition system at all. The distributor has no points (electric HEI I assume) and only three wires coming from it.
So I have three wires coming from the dizzy (plus earth), 4 terminals on the switchbox, a coil (2 terminals) and a condensor (1 wire and earth). So in this type of very basic system, what does the switch box do?
How can I test the switch box?
How can I test the distributor ignition system (HEI)?
Thanks in advance.
Mick
Thanks in advance.
Mick
