Re: 72Johnson 50hp hydro-electric/won't turn over
Sounds like a switch problem. I would ohm out the wires at the switch to check for a switch or wiring problem.<br /><br />But first I would make sure the shifter "neutral saftey swich" is not stuck. Rock the shifter back and forth at the helm and see if she will turn over.
