Quick question for all you ignition gurus (sp).<br />It appears a new stator is in my future.Motor runs pretty good but the spark is fairly weak in my opinion. Did a quick once over and the leads from the charge coil appear to out of spec. Measured about 800 ohms . Removed the flywheel to take a look and both coils are oozing out their inners. As I understand from searching through numerous sources these should be between 550-700 ohms . The installed unit appears to be a 6 amp stator. Is it ok to just replace it with a 12 amp unit ? I figure more capacity has to be better. Looking at other ignition parts ie rectifier coils etc. the same part numbers are given for 6 or 12 amp. Is the flywheel different ?<br /><br />Ok so not so quick but any input is appreciated.<br /><br />Thanks , Mike
