I've disassembled both cards on my v4 Johnson, soaked them in decarb, and replaced all o-rings, seals and floats using the appropriate rebuild kits.
When I soaked the fuel trays or resevoirs (the lower component of each card that holds the fuel), I didn't remove the brass fuel line connector. Should I remove this piece? Is there an o-ring or seaI? If there is an o-ring or seal, then the decarb probably ate it. I don't know if it would be easy to remove this piece or if the kits come with the necessary o-ring/seal. If someone out could lend some advice, I'd sure appreciate it.
Also, the needle with the kits did not have the plastic/rubber coated tip like the ones I removed. I've read a thread in this forum that said this was a problem. I've saved the old ones, but was is the general consensus with this? Are there usually problems with the bare metal tips?
