Running over 3500 rpm will cause the motor to overheat within a few minutes, Pump and thermostat are good. I also notice that of the two outlet holes behind the motor, one does not throw quite as much water when the thermostat opens, no obvious clogs that I can see. I would really like to pull the heads and exhaust cover to give it a good cleaning, however, due to it's age, i am reluctant to because I can see myself breaking bolts or rounding off the heads of them, creating nothing but more problems.
I have read a few posts which suggest that running vinegar through the block will clean out salt deposits. My thought is to remove the two rubber hoses which feed water to the block and manually pump vinegar into the block.
Any thoughts on this vinegar idea? My only thought is, if either the vinegar or my taking wrenches to it "F's" it up, I'll have an excuse to repower the boat.
