73 135 rebuild questions
rob 135
Got pistons and crank back in , question #1 , my block halves have the spaghetti seal. Do you just puts sealer right over seal? Not sure where sealer goes. Question #2 looking down at my reeds they look open slightly ,is that ok or normal ?
boobie
Re: 73 135 rebuild questions
I've always put just a small amount of sealer in the groove to hold the seal in and then some more over the top of it. Your reeds are normal.
emdsapmgr
Agree. The reeds will close/seal when under compression and function normally they way they are.
rob 135
Was just putting block halves together and found spaghetti seal fits fine on one side , the other it's not close to short .both side seals are same just one side groove is different. Any ideas, I could cut it and make work. With the proper sealer will it seal?
rob 135
image.jpgimage.jpgimage.jpg. Got powerhead all on and together . All new pistons, bearings and gaskets. Now to button it up , clean carbs and set timing . Then hope all goes well .
boobie
What's all the red stuff I see on the motor ????
rob 135
It's spray sealer . Tacks up to hold gasket
