Ive made a couple of posts on here about my fixing the head gasket to get this motor running.
Gasket finally came in. I installed it and put the motor back together.
I have yet to put the rope pull starter back on so I am using my cordless drill and a 3/4 bolt to turn the engine. I set the carb mix just as specified in the top secret file and in my manual.
It took several revolutions but finally kicked off. It ran like a screaming demon so much so that water was splashing everywhere.
I wasn't sure which knob to turn but I turned one and it slowed then died.
Then I could not get it to start So I opened the knob back up and cranked it several times and bang off like a demon again.
I got tired of messing with it and It appears that there may be fuel leaking from the carb.
I'm inclined to think that perhaps it is getting flooded and then I crank it a bunch and finally it fires off and then before I can adjust it it dies.
I think I need to go ahead and rebuild the carb properly as all I did was clean it.
