anthony_sav
- Joined
- May 8, 2003
- 2
motor shifts fine manually at motor, control box somtimes will not throw it in fwd. shift it in manually at motor it will open up and run at top end. When the control box works and throws it in fwd the motor will not open up. While shifting the control box you can see it always will shift into reverse & nuetral but somtimes will not pull into fwd. Would this problem be the cables or control box? This boat has been inactive for 3 or 4 years, could it be greased? Any comments would be greatly appreciated.
