65ESL73R - When I rebuilt the 3 carbs, the top carb needle valve had a small metal clip which hooked to the float. The other two carbs did not and the needle valvle had no barb for a clip, it was just flat. The carb kit had new needle and seats with clips for all 3. I installed them on all 3 since that seemed like the correct thing to do.
1: Did I do the right thing by installing the clips on all 3 and not jsut the top carb?
2: If so, why would there not have been clips on all 3 in the first place?
It seems to run much better now although I have not yet tank or lake tested. It just sounds much different.
3: I am sure that is mostly the carb rebuild, but could have the needle and seat not having clips caused some of the issues I was seeing with low speed stalling and rough starts? Has anyone else ever seen this?
Thanks in advance, any direction is much appreciated.
