yamadirt426
- Joined
- Aug 11, 2007
- 23
Picked up this motor. Everything runs and works good except it smokes blue pretty bad. I got the motor ,changed the leg oil ,changed the plugs,cleaned the carb, did comp test 63/73, then did a decarb with seafoam, (run only in a barrel so far) did another comp test now 64/70. Gonna do a run hopefully tonight or tomo but I have a feeling i'm gonna be doing piston and rings. Is the run on the water gonna make a diff ? I high idled seafoam with gas for about 15min and put in cylinders, then waited and then through carb and revved her on and off . She smoke white then back to her usual blue. Minimal at idle but fairly smokey at higher revs. She pumps water pretty good so the water run isn't gonna hurt and she actually runs good in the barrel just smokey. What do you brains think? I should have water run it before I posted but just waiting for the rain to stop which I think it just has
.what else would make it smoke so much. I did notice the end of my rich/lean adjustment screw has a bad nick on the taper in the carb? I dont think that could be it though
